28-06-2024, 11:27 PM
Thanks. I've rebuilt the front brakes with new cams, levers and brake shoes. Then I had to have a longer front cable made because the brake levers are so far forward compared with the rearward bias of the old cams and levers. Two clicks of the adjusters from the "zero" position lock the brakes on, with the new brake levers are sitting at 45 degrees towards the front of the car. So I'm kind of wondering if everything that I've done is okay.
Cheers, Geoffrey
