14-05-2018, 09:27 PM
The battery will be 50 to 80 ampere hours so as the running ign current is only about 2 amps can go a long way. Do not attempt in your modern. But best to avoid deep discharges as very hard on battery. And repeat recharges at trickle amps also reckoned not good fro battery.
It is more or less normal for Seven armatures to have been cooked with solder flung from the commutator, but it would be interesting to know just exactly what was diagnosed as the faults. Commutators worn/turned very thin to the extent that the petals bend out or will is the ultimate end. Does anyone know if reconditoners have a source of replacement commutators?
