PLC2 Ignition Switch
You can put a switch between 'IG' and 'A' to bypass the PLC2 ignition switch.
If you push the ignition key in fairly hard and it works, then it might be worth doing my 'bodge' to
get the switch to work.
Basically it is gluing a washer over onto the switch ( Superglue GEL recommended).
It does work, but also have an ignition switch wired across 'just in case'.
Martin, GM6VXB
PLC2 Ignition Switch - by airarms64 - 12-06-2024, 09:05 AM
RE: PLC2 Ignition Switch - by GM6VXB - 12-06-2024, 09:53 AM
RE: PLC2 Ignition Switch - by Tony Griffiths - 12-06-2024, 10:10 AM
RE: PLC2 Ignition Switch - by GM6VXB - 12-06-2024, 10:59 AM
RE: PLC2 Ignition Switch - by airarms64 - 12-06-2024, 06:35 PM
RE: PLC2 Ignition Switch - by Colin Morgan - 13-06-2024, 06:24 PM
