You are correct, Hugh. However, various aftermarket versions were not marked. Furthermore I have a small collection of aftermarket non Girling brake cams in which the cotter positions vary by a marked extent. Perhaps the same is true of aftermarket Girling cams? Ruairidh can doubtless tell us.
Ah, I see from above that he has done so already! The moral is evidently, put your faith in Lord Austin’s version and check that against the replacement.
Regards,
Stuart
Regards,
Stuart
