Sound deadening in an A7...
#25
I think the dimpled sound deadening material with a black bitumen like finish was first used for the 1936 range of 'streamlined' Austins.  I have a Practical Motorist road test of the Austin Ten Cambridge dated 2nd January 1937 which makes a point about the sound deadening used in the bodywork.  There is a photo of the drivers footwell with the carpet folded back, under which is a layer of felt. The dimpled bitumenised material is glued to the floor.   I suspect if it has a bitumen finish it will stay in place and bond itself to the floor.   My brother had a 1936 Ten Cambridge and the dimpled material was applied to all the body panels up to window level.
There is a type of foam carpet underlay that has a very similar dimpled finish.   If this was painted underneath with bitumen I imagine it would be quite effective.
I am following this thread with interest as the Pytchley saloon will soon be on the road.  This has a stressed plywood body that amplifies any noise.  Rather like a motorised double bass!
Sound deadening in an A7... - by Ruairidh Dunford - 09-05-2018, 08:24 PM
RE: Sound deadening in an A7... - by Steve kay - 09-05-2018, 09:27 PM
RE: Sound deadening in an A7... - by AllAlloyCup - 10-05-2018, 08:26 AM
RE: Sound deadening in an A7... - by Chris KC - 10-05-2018, 09:38 AM
RE: Sound deadening in an A7... - by Chris KC - 10-05-2018, 10:09 AM
RE: Sound deadening in an A7... - by squeak - 11-05-2018, 12:36 AM
RE: Sound deadening in an A7... - by squeak - 11-05-2018, 01:48 AM
RE: Sound deadening in an A7... - by Nick Salmon - 11-05-2018, 07:13 AM
RE: Sound deadening in an A7... - by DavidL - 11-05-2018, 08:31 AM
RE: Sound deadening in an A7... - by Dave Wortley - 11-05-2018, 08:50 AM
RE: Sound deadening in an A7... - by Chris KC - 11-05-2018, 09:47 AM
RE: Sound deadening in an A7... - by squeak - 11-05-2018, 10:10 AM
RE: Sound deadening in an A7... - by DavidL - 11-05-2018, 10:27 AM
RE: Sound deadening in an A7... - by Chris KC - 11-05-2018, 10:30 AM
RE: Sound deadening in an A7... - by Ian Williams - 11-05-2018, 09:26 PM
RE: Sound deadening in an A7... - by Peter Naulls - 11-05-2018, 09:52 PM
RE: Sound deadening in an A7... - by Nick Salmon - 11-05-2018, 10:10 PM
RE: Sound deadening in an A7... - by Malcolm Parker - 12-05-2018, 12:57 PM
RE: Sound deadening in an A7... - by Oxford Jack - 12-05-2018, 04:40 PM
