Just another run out in Ruby.....
#33
If the engine is rubber mounted earthing can be a problem.  A pal once noticed that the choke cable on his Austin 7 was hot and it turned out that it was acting as the main earth.
Sorry to hear that your trip is not as originally planned but it's better than the car letting you down when you are between Cape Wrath and  John O Groats!
RE: Just another run out in Ruby..... - by Malcolm Parker - 16-05-2024, 01:32 PM
