10-05-2024, 06:05 PM
Hi
Starting a car with electronic ignition by the handle may be problematic (or so I’m told by Powerspark). Apparently their ignition works on a series of pulses so you may need to crank quite quickly, in addition the timing needs to be set by strobe rather than a static timing light.
I’d put a points based dizzy on, set the points to just start to open at TDC and you may find the car starts.
