  • 1 Vote(s) - 2 Average
Neither would be a route I would choose to go.
You either need to modify a later 4 speed flywheel to accept the early cover plate, or find a 1929-32 three speed flywheel, or fit a brand new 1 1/8" crankshaft.
Currently, if you wish to use the 1 5/16" crankshaft, you will need to alter/change the flywheel, modify the front main lip, use later rods, grind a little material from the centre camshaft ring housing, use a later rear main bearing, thrower and cover plate, and drill an oil escape hole.
RE: Greetings! New owner from India - by Chris KC - 19-09-2023, 12:49 PM
RE: Greetings! New owner from India - by jpsmit - 19-09-2023, 01:04 PM
RE: Greetings! New owner from India - by David.H - 22-09-2023, 02:00 PM
RE: Greetings! New owner from India - by David.H - 26-09-2023, 05:16 PM
RE: Greetings! New owner from India - by stuartu - 18-12-2023, 10:20 AM
RE: Greetings! New owner from India - by Chris KC - 18-12-2023, 11:18 AM
RE: Greetings! New owner from India - by falcott - 18-12-2023, 07:07 PM
RE: Greetings! New owner from India - by falcott - 19-12-2023, 06:58 PM
RE: Greetings! New owner from India - by Chris KC - 05-02-2024, 10:56 PM
RE: Greetings! New owner from India - by Chris KC - 09-02-2024, 11:09 AM
RE: Greetings! New owner from India - by Belinni - 20-02-2024, 01:02 PM
RE: Greetings! New owner from India - by falcott - 29-03-2024, 07:44 AM
RE: Greetings! New owner from India - by Ruairidh Dunford - 06-05-2024, 02:07 PM
