26-04-2024, 09:33 AM
(This post was last modified: 26-04-2024, 09:34 AM by Tony Griffiths.)
"....could there be an issue with the coil and dynamo to create the interference in the first place?" The dynamo and ignition do provide the necessary interference, but do you mean that there might be a fault with the systems? This could be the case, as one of my cars an all-LED-bulb-electronic-flasher system works perfectly but on another, fitted at the time with the same models of distributer, coil and dynamo, it didn't. I did try swapping over the coils to see if it would make any difference, but it didn't and I was too busy doing other stuff to take it further.
