Crown Wheel Question
It looks like to much blue was used.
A look at the pinion end as well as the crownwheel will help.
My back axle was set up using a gauge which might well have been an original Austin one Borrowed from a fellow owner and fettler.
Best of luck with your setting up
At least we have quite a lot of adjustment on our axles to vary the pinion engagement with the shims then sideways mesh adjustment on the castle nuts.
Have you tried fitting the crownwheel in a different bolt orientation to se if the runout can be reduced.
It only takes a tiny bit of dirt or a burr on a hole edge to cause run out.
Crown Wheel Question - by MatthewMyerscough - 24-03-2024, 01:57 PM
RE: Crown Wheel Question - by Howard Wright - 24-03-2024, 02:45 PM
RE: Crown Wheel Question - by MatthewMyerscough - 24-03-2024, 07:27 PM
RE: Crown Wheel Question - by MatthewMyerscough - 14-04-2024, 05:15 PM
RE: Crown Wheel Question - by Ian Williams - 14-04-2024, 10:03 PM
RE: Crown Wheel Question - by MatthewMyerscough - 15-04-2024, 07:41 PM
RE: Crown Wheel Question - by Ian Williams - 16-04-2024, 12:33 PM
RE: Crown Wheel Question - by MatthewMyerscough - 16-04-2024, 09:12 PM
RE: Crown Wheel Question - by Ian Williams - 16-04-2024, 10:16 PM
RE: Crown Wheel Question - by Terry McGrath - 17-04-2024, 11:44 AM
RE: Crown Wheel Question - by Nick Salmon - 17-04-2024, 12:06 PM
RE: Crown Wheel Question - by Ruairidh Dunford - 17-04-2024, 05:21 PM
RE: Crown Wheel Question - by MatthewMyerscough - 17-04-2024, 06:47 PM
RE: Crown Wheel Question - by Ruairidh Dunford - 17-04-2024, 09:02 PM
RE: Crown Wheel Question - by Chris Garner - 18-04-2024, 09:55 AM
RE: Crown Wheel Question - by Nick Salmon - 18-04-2024, 02:41 PM
RE: Crown Wheel Question - by Chris KC - 18-04-2024, 02:49 PM
RE: Crown Wheel Question - by Ruairidh Dunford - 18-04-2024, 11:17 PM
RE: Crown Wheel Question - by MatthewMyerscough - 19-04-2024, 06:19 PM
RE: Crown Wheel Question - by dickie65 - 19-04-2024, 08:02 PM
RE: Crown Wheel Question - by MatthewMyerscough - 30-04-2024, 06:54 PM
RE: Crown Wheel Question - by Robert Leigh - 30-04-2024, 09:55 PM
RE: Crown Wheel Question - by MatthewMyerscough - 02-05-2024, 06:28 PM
RE: Crown Wheel Question - by Ian Williams - 02-05-2024, 09:32 PM
RE: Crown Wheel Question - by MatthewMyerscough - 03-05-2024, 06:08 PM
RE: Crown Wheel Question - by Robert Leigh - 03-05-2024, 09:17 PM
RE: Crown Wheel Question - by MatthewMyerscough - 04-05-2024, 05:51 PM
RE: Crown Wheel Question - by MatthewMyerscough - 23-05-2024, 08:02 PM
RE: Crown Wheel Question - by Ian Williams - 23-05-2024, 09:29 PM
RE: Crown Wheel Question - by MatthewMyerscough - 23-05-2024, 10:41 PM
RE: Crown Wheel Question - by Ian Williams - 24-05-2024, 01:39 AM
RE: Crown Wheel Question - by Chris KC - 24-05-2024, 07:12 AM
RE: Crown Wheel Question - by MatthewMyerscough - 24-05-2024, 06:34 PM
RE: Crown Wheel Question - by dickie65 - 25-05-2024, 01:46 PM
RE: Crown Wheel Question - by MatthewMyerscough - 26-05-2024, 09:50 AM
RE: Crown Wheel Question - by dickie65 - 26-05-2024, 06:08 PM
RE: Crown Wheel Question - by MatthewMyerscough - 28-05-2024, 06:25 PM
