  • 1 Vote(s) - 2 Average
#98
One often finds lift-the-dot studs all over the place - put there by an owner to fasten down a tonneau cover. There is also a rather clever fastening on the hood frame which, when resting on the rubber block at each side of the rear of the body, needs strapping down. To do this, a leather strap was riveted to the frame and the end fitted with a lift-the-dot that engaged on a stud that was also used to bolt the rubber block in place. Even with this strap in place. the hood frame often needs a second nearer the front.
.jpg   Original strap.JPG (Size: 212.1 KB / Downloads: 205)
.jpg   Original Bracket with rubber 1.JPG (Size: 317.76 KB / Downloads: 204)
.jpg   Rubber with Lift-the-Dot.JPG (Size: 361.07 KB / Downloads: 204)
RE: Greetings! New owner from India - by Chris KC - 19-09-2023, 12:49 PM
RE: Greetings! New owner from India - by jpsmit - 19-09-2023, 01:04 PM
RE: Greetings! New owner from India - by David.H - 22-09-2023, 02:00 PM
RE: Greetings! New owner from India - by David.H - 26-09-2023, 05:16 PM
RE: Greetings! New owner from India - by stuartu - 18-12-2023, 10:20 AM
RE: Greetings! New owner from India - by Chris KC - 18-12-2023, 11:18 AM
RE: Greetings! New owner from India - by falcott - 18-12-2023, 07:07 PM
RE: Greetings! New owner from India - by falcott - 19-12-2023, 06:58 PM
RE: Greetings! New owner from India - by Chris KC - 05-02-2024, 10:56 PM
RE: Greetings! New owner from India - by Chris KC - 09-02-2024, 11:09 AM
RE: Greetings! New owner from India - by Belinni - 20-02-2024, 01:02 PM
RE: Greetings! New owner from India - by falcott - 29-03-2024, 07:44 AM
RE: Greetings! New owner from India - by Tony Griffiths - 17-04-2024, 07:51 PM
