Gas and Ignition levers on steering wheel
Thank you both for your advice. I will leave as it is for now. As I said it appears to be statically timed with steering wheel switch set in the centre. I will have a play on the road to see the effect. Given that later Sevens had an automatic advance I am not too sure that I understand where my DJ4 car is deficient in timing.
Thanks again
RE: Gas and Ignition levers on steering wheel - by Old Dave - 17-04-2024, 06:48 PM
