14-04-2024, 01:17 PM
If the torque tube ball joint is ok and the hubs are tight the other possibility is that the pinion drive flange is not completely secured. Its securing nut is revealed when you disconnect the rear propshaft joint.
Regards, Stuart
Regards, Stuart
