14-04-2024, 07:46 AM
You won't get backlash between the crown and pinion if the problem is end float in the pinion shaft- the pinion winds up and down as you rotate the top flange.
Differential Wear
Messages In This Thread |
Differential Wear - by Graham Barker - 13-04-2024, 05:51 AM
RE: Differential Wear - by Chris KC - 13-04-2024, 08:26 AM
RE: Differential Wear - by Charles P - 13-04-2024, 08:59 AM
RE: Differential Wear - by Graham Barker - 13-04-2024, 10:34 AM
RE: Differential Wear - by Tony Press - 14-04-2024, 01:12 AM
RE: Differential Wear - by Graham Barker - 14-04-2024, 05:04 AM
RE: Differential Wear - by Tony Press - 14-04-2024, 07:46 AM
RE: Differential Wear - by Ian Williams - 14-04-2024, 08:26 AM
RE: Differential Wear - by Charles P - 14-04-2024, 02:20 PM
RE: Differential Wear - by Graham Barker - 14-04-2024, 08:11 PM
RE: Differential Wear - by Tony Press - 15-04-2024, 01:54 AM
