Rear hub thread - damage
Having had a precisely similar problem with a rear hub, I have found that, If all else fails, one can remove a rear hub as follows:-
Replace the axle shaft nut so that it is flush with the end of its thread to protect it. Just swing (don’t strike) the end of the axle shaft with a sledge hammer. Let the weight of the hammer do the work. This will drive the axle shaft inwards, and the shock should release the hub’s taper.
I should mention that this is not an original idea, it was suggested in a post on this forum some time ago, and it works!
Rear hub thread - damage - by Old Dave - 05-04-2024, 04:24 PM
RE: Rear hub thread - damage - by Chris KC - 05-04-2024, 05:14 PM
RE: Rear hub thread - damage - by Andy Bennett - 05-04-2024, 05:19 PM
RE: Rear hub thread - damage - by John Cornforth - 05-04-2024, 05:32 PM
RE: Rear hub thread - damage - by Nick Salmon - 05-04-2024, 06:27 PM
RE: Rear hub thread - damage - by Old Dave - 05-04-2024, 07:46 PM
RE: Rear hub thread - damage - by Steve Jones - 05-04-2024, 07:46 PM
RE: Rear hub thread - damage - by Nick Salmon - 05-04-2024, 08:01 PM
RE: Rear hub thread - damage - by Ian Williams - 05-04-2024, 08:31 PM
RE: Rear hub thread - damage - by David Stepney - 05-04-2024, 08:54 PM
RE: Rear hub thread - damage - by Tony Press - 05-04-2024, 09:39 PM
RE: Rear hub thread - damage - by Chris KC - 05-04-2024, 09:49 PM
RE: Rear hub thread - damage - by Charles P - 05-04-2024, 10:07 PM
RE: Rear hub thread - damage - by Ian Williams - 06-04-2024, 02:14 AM
RE: Rear hub thread - damage - by Howard Wright - 06-04-2024, 06:32 AM
RE: Rear hub thread - damage - by Jamie - 06-04-2024, 08:58 AM
RE: Rear hub thread - damage - by Old Dave - 07-04-2024, 08:02 PM
RE: Rear hub thread - damage - by JohnD - 08-04-2024, 08:59 AM
RE: Rear hub thread - damage - by John Mason - 08-04-2024, 09:14 AM
