Removing broken sump bolts
Yes, gone for the silicon gasket.
Interestingly it says: USE A THIN SMEAR OF HYLOMAR OR SILICONE SEALER WHEN ASSEMBLING.
Personally from experience with silicon gaskets albut in an RF and electronic environment, I will
initially try with only a light smear of high temperature silicon grease.
Martin.
Removing broken sump bolts - by GM6VXB - 26-03-2024, 08:38 AM
RE: Removing broken sump bolts - by Chris KC - 26-03-2024, 09:29 AM
RE: Removing broken sump bolts - by GM6VXB - 26-03-2024, 03:35 PM
RE: Removing broken sump bolts - by Steve Jones - 26-03-2024, 04:05 PM
RE: Removing broken sump bolts - by Robert Leigh - 26-03-2024, 04:22 PM
RE: Removing broken sump bolts - by Colin Morgan - 26-03-2024, 05:17 PM
RE: Removing broken sump bolts - by AustinWood - 26-03-2024, 06:28 PM
RE: Removing broken sump bolts - by David Stepney - 26-03-2024, 09:04 PM
RE: Removing broken sump bolts - by GM6VXB - 27-03-2024, 12:49 PM
RE: Removing broken sump bolts - by AustinWood - 27-03-2024, 02:27 PM
RE: Removing broken sump bolts - by Rick F - 27-03-2024, 04:17 PM
RE: Removing broken sump bolts - by Reckless Rat - 27-03-2024, 04:50 PM
RE: Removing broken sump bolts - by GM6VXB - 27-03-2024, 08:09 PM
