27-03-2024, 04:50 PM
If you are using a silicone gasket, the mating surfaces should be dry. No grease, no gasket compount. Clean the joint surfaces with acetone prior to assembly. Torque the joint down and then again after 24hrs to allow for spread. After that, it's fit & forget.
