Removing broken sump bolts
Some sump bolt holes are 'blind', ie do not go into the sump. Which ones varies with the year of manufacture. If there is crud in these holes the sump bolts bottom early and snap very easily. It's a good idea to make sure they are clear.
If the sump wasn't leaking with the 2 broken bolts it may well be OK anyway.
Removing broken sump bolts - by GM6VXB - 26-03-2024, 08:38 AM
RE: Removing broken sump bolts - by Chris KC - 26-03-2024, 09:29 AM
RE: Removing broken sump bolts - by GM6VXB - 26-03-2024, 03:35 PM
RE: Removing broken sump bolts - by Steve Jones - 26-03-2024, 04:05 PM
RE: Removing broken sump bolts - by Robert Leigh - 26-03-2024, 04:22 PM
RE: Removing broken sump bolts - by Colin Morgan - 26-03-2024, 05:17 PM
RE: Removing broken sump bolts - by AustinWood - 26-03-2024, 06:28 PM
RE: Removing broken sump bolts - by David Stepney - 26-03-2024, 09:04 PM
RE: Removing broken sump bolts - by GM6VXB - 27-03-2024, 12:49 PM
RE: Removing broken sump bolts - by AustinWood - 27-03-2024, 02:27 PM
RE: Removing broken sump bolts - by Rick F - 27-03-2024, 04:17 PM
RE: Removing broken sump bolts - by Reckless Rat - 27-03-2024, 04:50 PM
RE: Removing broken sump bolts - by GM6VXB - 27-03-2024, 08:09 PM
