Chummy Hood Fitting to Body Tub
Thanks all that's helpful.
There's no aluminim trim strip on the car at present - I assume it's just pinned/screwed into place at the same time as the hood? I'd think that the rear of the hood is under a fair bit of tension when it's up so presumably needs to be quite firmly attached. It seems a bit crude that there would be pins/screws going straight through the fabric, surely this would lead to tearing unless it's primarily the trim strip keeping it in place rather than the pins?
Chummy Hood Fitting to Body Tub - by RupertW - 26-03-2024, 11:16 AM
RE: Chummy Hood Fitting to Body Tub - by RupertW - 26-03-2024, 05:13 PM
RE: Chummy Hood Fitting to Body Tub - by Parazine - 26-03-2024, 11:50 PM
