26-03-2024, 02:27 AM
(25-03-2024, 01:39 PM)NickĀ Lettington Wrote:(25-03-2024, 01:12 PM)SteveĀ Jones Wrote: Agree with Ruairidh that these locations are the most likely to be open. However,, to loose a sump full of oil does seem excessive even if all locations are leaking. You did put the sump plug in and fully tighten it didn't you. A regular poster on here made that mistake some years ago!! I gave up with sump studs a few engines ago and now use 1/4" BSW Engineering studs with nylocs. Fitted with a silicone sump gasket, sump oil leaks are a thing of the past - as long as you fit the sump plug.
Never mind the studs... that's a great engine stand you have Steve.
Steve is a proper Yorkshireman
