Camshaft Pinion Stuck
Yes it’s the shock force of the hammer when the taper is under tension that releases the grip. Similar methods can be used on other tapers such as track rod ends on moderns. Use a long bar to put a downwards force on the bottom wishbone then with the nut removed give a sharp strike the ring the taper goes through.
John Mason
Camshaft Pinion Stuck - by John Cornforth - 13-03-2024, 08:15 PM
RE: Camshaft Pinion Stuck - by AustinWood - 13-03-2024, 11:45 PM
RE: Camshaft Pinion Stuck - by John Mason - 14-03-2024, 11:10 AM
RE: Camshaft Pinion Stuck - by John Cornforth - 14-03-2024, 03:18 PM
RE: Camshaft Pinion Stuck - by AustinWood - 14-03-2024, 05:09 PM
RE: Camshaft Pinion Stuck - by John Mason - 14-03-2024, 08:45 PM
RE: Camshaft Pinion Stuck - by Parazine - 14-03-2024, 11:02 PM
