Cylinder block centre bolt crack
Hi
If you leave as is make sure to seal in the centre stud with some sealant. There is a water path across the crack and up the threads ending up spurting out of the centre head stud!. Also make sure the centre stud is set well down in the block as the crack might weaken the thread near the top of the block.
RE: Cylinder block centre bolt crack - by Alan - 12-03-2024, 10:00 AM
RE: Cylinder block centre bolt crack - by Howard Wright - 12-03-2024, 11:35 AM
RE: Cylinder block centre bolt crack - by Dirk73 - 15-03-2024, 08:17 PM
