Car type: 1932 RN saloon
Threads on your Zenith carb are metric. The screws holding the float chamber bowl to the carb body are m7 (course or fine?) I am not sure what the other threads are, fuel pipe union/nipple and jet threads plus emulsion block. Someone on here will be able to tell you. Also the Nippy/65 would have had a Zenith downdraught carb originally but again someone will be able to tell you the correct item.
Car type: austin nippy 1937
Jon; thanks for the parts list links. I have #1406 but had not seen #1169. right now I am most interested in seeing what the LHD brake and clutch pedals are supposed to look like.#1406 lists LHD part #s but no illustrations. #1169 does not list LHD parts. I believe the steering column in my car is correct but the pedals are a mess.
Thanks
Randy
Car type:
write something for the archive site with a few photos and we can put up an appeal - you need some lhd owners coming out of the shadows...
Hi Randy I am in Vancouver BC. I have owned couple of Austin Sevens for over 62 years (1927 Chummy & Ulster replica) and have Built a few engines for Austins in the Pacific North West. My email address is kenmorton@telus.net
Ken Morton
Car type: 1936 2 seater tourer LHD 1930 Boat tail
Hello, I have no idea if the pedals would be the same as a Nippy, but can send a photo of the pedals on our LHD Opal (ex USA) if that helps. Advice welcomed.
Charlie.
