All my cars have LEDs, well those that have lights do, and although I met Ian Anderson on a train one night I didn’t have the heat to tell him I preferred Louis Armstrong.
Alan,
My father’s passport from around 1965 - it caused a lot of raised eyebrows as he travelled back and forward across the Atlantic…
.jpeg   C2DB25DF-7803-4F46-9B19-36BC72E84369.jpeg (Size: 126.85 KB / Downloads: 351)
(31-12-2023, 01:07 PM)Ivor Hawkins Wrote: I suppose I ought to “get with the programme” but like Ian Anderson, I’m living in the past…
Could be worse, you might be Thick As A Brick.
I’ll get my coat…….
No problem with an RN with incandescent headlamps, LED rear lights and a vacuum wiper motor      it works perfectly with new cup washers.
I’m intrigued
(31-12-2023, 03:26 PM)Ruairidh Dunford Wrote: Alan,
If this weather keeps up
We might need an Aqualung !!
Alan,
The ship Ian was working on go frozen in the St Lawrence River, they walked over the ice to a bar where he was playing.
The only thing he had on him for an autograph was his passport.  For some years his spouse was Louis Armstrong.
(31-12-2023, 06:06 PM)Dave Mann Wrote: No problem with an RN with incandescent headlamps, LED rear lights and a vacuum wiper motor   it works perfectly with new cup washers.
Me, too. No problem with projector-type LED headlamps bulbs, LED rear lights, 12-volt LED indicators powered from a small 12-volt battery - and a suction pump driving the vacuum wiper!
What I have noticed with the headlamps - and it's a 'blindingly' obvious thing I suppose - but the one car with clear glass headlamps and these bulbs has a spot-on beam pattern. Two others have textured glasses, and the one with the roughest texture has almost no beam pattern at all.
Brilliant thread drift!
Next I’ll start the hunt for 6 volt LEDs, I have the old Seven Workshop Honda conversion reflectors, so I better whip the bulbs out and have a look.
Ivor
You may want to wait for the next Association Grey Mag (due out early January). There is an article on LEDs which might be useful!
Users browsing this thread: Stan, 20 Guest(s)
