Neatsfoot oil whatever that is.
Screw thread on Vacuum wiper
04-12-2023, 10:50 AM
04-12-2023, 11:07 AM
Yes, I was told neatsfoot oil was the right stuff, but couldn’t find any on my shelf in the workshop!
04-12-2023, 12:58 PM
(This post was last modified: 04-12-2023, 01:00 PM by Colin Wilks.)
When renewing the leather gaiters that surround the swivel hubs on my ex military Land Rover lightweight I impregnated them with copious amounts of vaseline, which made them pliable, water proof and slippery, which sounds like the spec of what you are hoping to achieve.
05-12-2023, 10:24 AM
A Merry Christmas to all Box Saloon owners - warm and cosy in the winter weather.
06-12-2023, 03:07 AM
I've obtained a small bottle of Neatsfoot oil to treat the leather cups with. The question is how much to use and where to apply it ? Directions for use welcomed.
Stephen
06-12-2023, 09:19 AM
Put some in a saucer and soak the leather seals in it overnight. Wipe off the excess and fit the seals.
10-12-2023, 04:01 AM
A thought occurred to me when restoring this vacuum wiper motor. Why not make a vacuum tank that is plumbed into the vacuum tube between the engine and the wiper ? Perhaps a one- way valve on the suction side to maintain the vacuum.
What are your thoughts or experiences? Cheers, Stephen
10-12-2023, 10:06 AM
(10-12-2023, 04:01 AM)Steve Bryant Wrote: A thought occurred to me when restoring this vacuum wiper motor. Why not make a vacuum tank that is plumbed into the vacuum tube between the engine and the wiper ? Perhaps a one- way valve on the suction side to maintain the vacuum. As fitted to 1950's side-valve Fords.
10-12-2023, 12:43 PM
(10-12-2023, 04:01 AM)Steve Bryant Wrote: A thought occurred to me when restoring this vacuum wiper motor. Why not make a vacuum tank that is plumbed into the vacuum tube between the engine and the wiper ? Perhaps a one- way valve on the suction side to maintain the vacuum. Steve, I've spent most of my career in brake systems and - as I'm sure you realise - that's how brake vacuum servos are done. I guess the main issue would be where to put it. A simple plastic NRV on the engine side should suffice to retain vacuum in the reservoir - assuming everything else seals adequately. From a "design" side the thing you'd have to figure out is how big is enough? I have no idea how much vacuum is 'consumed' by the wiper. You could potentially end up in a dead spot where the vacuum in the tank is quickly exhausted and the suck from the engine is insufficient to evacuate the tank back to a level where the wipers work properly (maybe - just thinking out loud). Another possibility - for those who are hell-bent on making it work and perhaps less concerned about originality - would be a small electric vacuum pump. That could probably be installed out of sight somewhere and should guarantee a steady 'suck'. |
