Hi Ian
I Have two copper gaskets that Marcus Altered for me.
just wondering were the weakness was in original ones.
modifications to my two are no WATER JACKET HOLES AND 60mm bore
Cheers Colin
Ian I will be interested in what Marcus has to say, if we are to proceed put me down for 2. I had not thought bore size to be relevant as off the shelf seems to be 1 size fits all but for the record I believe my engine will be +20 with standard valves. regards Russell
The weakness is probably of no great consideration for you Colin as it was related to waterway holes and insufficient material between bore 2 and 3. If you have dry decked your engine this really is the best answer with solid gaskets in my opinion.
Marcus may I order a couple of the mark 2 version if you do decide to run a batch, thanks Russell
Hi All,
This is not a problem just for solid copper gaskets,
It is all down to corrosion of the block and head regardless of them being cast iron or alloy
One way to correct is drill water jacket holes untill out to (CLEAN) material then plug with ether cast iron or alloy and weld in place Redrill holes to correct size then surface grind .
some will say this will be expensive but in the scheme of things not really you only have to look at the number of water leak problems that turn up on this site
Thats just my way of doing it
Regards Colin NZ
Hi Russell,
I will let you know how we get on.
Marcus
The solid copper gaskets were made for Ulster and Nippy heads which have a different shaped head mating surface.
the normal high and low compression gaskets have a different shape again.
There are there different shaped gaskets dependant on your head shape.
The PAYEN Head gasket I have is correct for the Nippy and Ulster heads.
I would need to get my gasket scanned to make a file suitable for my local company to cut a few for me.
