Car type: 1932/3 AH tourer
I am sure this has been asked before but what should be the size of number plate letters and numbers for a 1932/33 Seven The 'stencil firms' seem to offer both 3" and 3.5" tall... My existing (pressed ali, later replacement) digits measure 3.25". Be grateful for guidance. Thanks.
Adrian
Thanks, I’ll have a look!
Hi
My 27th edition of the Motor Manual dates from the late 1920's and gives the sizes in the "Motorist and the Law" section. The same sizes are quoted in a later edition from the 1950's.
Letter height 3 1/2 inches
Letter stroke width 5/8 inch
Letter width 2 1/2 inches (except for figure 1)
Space between letters 1/2 inch
Space between letters and numbers 1 1/2 inches
Space between letters/numbers and top or bottom of plate 1/2 inch minimum
Space between letters /numbers and side of plate 1 inch minimum
There is no specific font that is 'correct'. The letters had to be a consistent width, but for example the nine could be very 'square' like Howard's plate or much more rounded with a simple 'tail'.
Back in the 30's a font was something babies were baptised in... many registration plates were hand-painted.
I used a stencil from 'classic transfers' for mine and was very pleased with the result & their service.
As for size, a friend of mine has a plate with slightly undersize characters and it has not attracted a single comment in a good 4 decades of motoring.
Thanks everyone. You've all confirmed which way I'll be going.
