I have fitted over 100 of the complete Accuspark units. I also run 6 of my cars on them, very successfully. They improve starting, smooth running and pick up.
They work extremely well provided you follow the steps below.
Ensure that all electrical connections are tight, as any arcing/short will instantly fry the unit.
Ensure that your coil has a minimum of 2.4ohms of protection, any less and it will erode the unit, leading to failure.
As with any distributor, you should always carry a spare (conventional or electronic, your choice) or risk being left stranded (gears can fail too)!
Car type: Austin 7 RN 1931
Hi
My distributor is a Powerspark unit purchased via eBay. Not sure how the advance works as I've yet to take it apart.
The only 'problem' I encountered is to set the initial timing as there are no reference points, no pun intended.
A cheap strobe and an intelligent guess got it fairly close and then it was just fine tuning. Haven't touched it since installation and set up.
The strobe shows the advance curve. I locked off the manual advance lever on the steering wheel as it is not needed.
I drive my RN on all sorts of Welsh roads, flat and hilly and have yet to experience any problems.
Car type: Ruby
15-05-2023, 08:17 PM
(This post was last modified: 15-05-2023, 08:20 PM by k8207418.)
Do all the electronic versions have bob weights for auto advance or do some use some electjiggerypokery to do that ?
So far as I know, they all rely on mechanical methods.
Car type: Ruby
Thanks
I will go for the Accuspark
Thanks
I recommend buying a spare base plate, to carry in the car with you.
Car type: Ruby
I was thinking carrying the old distributor
Why just base plate ?
16-05-2023, 08:37 AM
(This post was last modified: 16-05-2023, 08:39 AM by Ruairidh Dunford.)
Because, if the original one fails, you can simply swap it over in a matter of minutes. You won't upset the timing, the wiring remains the same, it's good practice to carry spares of things like this...
To be clear, I am suggesting you buy a spare electronic base plate, when you purchase your new unit.
Carrying your old conventional distributor is a good idea too.
