12-05-2023, 07:01 PM
Wheel nut angle.
Does anyone know the correct angle for the wheel nuts
Thanks
Thanks
Wheel nut angle
Wheel nut angle.
Does anyone know the correct angle for the wheel nuts Thanks
12-05-2023, 10:47 PM
I can't actually answer but what ever it was I increased it slightly to make allowance for wear in the wheel and also shortened it at the pointy end to make sure it didn't bottom on the hub thread. I have over the years collected quite a few steel ones which don't suffer wear like brass, I wonder which make they may have come from?
13-05-2023, 04:14 AM
I can't answer your question except to say that I binned them several decades ago and replaced them with penny washers and 3/8" BSF nylocs, which don't come undone.
I've just bought some nice 1/8" thick washers x 3/8" x x 1.5" so let me know if you need supplier details.
13-05-2023, 05:12 PM
At first I thought the answer was 'horizontal', but then realised I would have to allow for the camber. Then I realised the question was perhaps referring to the chamfer on the end?
I have just looked at a new brass wheel nut, an old brass not and an old chromed one. As far as I can tell - with a set-square - the chamfer is 45 degrees. Is it critical? |
