Interesting pictures Mick, thanks for sharing. Note that on all three there is a clearly defined annular seat for a seal, which is what leads me to think Bob's example may be a replica, from a time when we weren't able to expect quite the same quality as we do now. Or it might just be the light...
Car type: 1932/3 AH tourer
Thanks everyone, especially Mick for those three photos. It is clear that my cap is the one on the left in photo 3, but yes you are all correct that it has been drilled through the crest, I imagine in the past to take a small flag post or similar, and yes again, time fettling this might be better spent elsewhere!
Oops, a voice from Powys tells me that I was thinking of the wrong sort of wings, so not flared Angel wings, which might not be original at all, but improvised from jumble discoveries. Apologies.
14-05-2023, 01:32 PM
(This post was last modified: 14-05-2023, 02:27 PM by Chris KC.)
Does anyone happen to know what thread was used on the centre post of the caps on the right in Mick's photo?
edit: Ah, found it: 3/16" BSF
On my RP I seal the rad cap with some silicone. It helps to keep the coolant in the system or at least direct any excess via the overflow. I very rarely have to top up.
I always assumed that the cap was designed to give an automatic screen wash on braking.!!
