22-04-2023, 01:45 PM
(This post was last modified: 22-04-2023, 02:45 PM by Chris KC.)
Is someone able to tell me please, what sort of screws were originally used to fix the RP windscreen hinge to the body under the peak of the roof?
I had kind of assumed they would be countersunk, but on closer inspection the hinge is not, and there seems ample space for perhaps a round head.
The holes in my hinge are 3/16" dia so I'm inclining towards a No.10 round head slotted woodscrew, would be nice to confirm though. Failing that anecdotal evidence or "yes I've got round headed screws" would be a fair substitute.
Thanks...
I use round head 2BA set screws because the wood in the peak was rotten and has been replaced by 1.5" X 0.25" steel strip suitably drilled and tapped.
23-04-2023, 02:30 PM
(This post was last modified: 23-04-2023, 02:31 PM by David Stepney.)
Just been to have a look at how the windscreen hinge is fitted to my own RP, given that it is reasonably original. Whatever was there originally has been replaced by brass countersunk screws which, because there are no countersinks in the hinge to take the heads, stand proud slightly. I suspect, therefore that originally the screws were dome headed. There is certainly enough clearance.
I have always used pan headed screwdriver slotted long self tappers for both the RN and RP type windscreen frames. It gives a really secure fixing with large head coverage over the screen hinge. You can then drive with the screen open with impunity.
I like to use stainless steel self tappers into wood, giving a long threaded grip and no problem with rust seizing things up should dismantling ever be required.
