4 speed Crash Gearbox Illustration
Some little while ago, someone (was it Tony Griffiths?) posted an illustration from one of the motoring magazines of a beautifully detailed cutout drawing of the 4 speed crash gearbox, but I am damned if I can find it. Can anyone point me in the right direction to find it please?
Two images here, David:
[Image: IMG-20230111-WA0005.jpg]
and the inside of mine :
[Image: IMG-20230111-WA0004.jpg]
And a more formal engineering drawing on the Archive web site...
https://archive.a7ca.org/collections/tec...em/TD0149/?
Thank you Bruce and Hugh, you are absolute stars!
Though I should point out that the Archivist has pointed you to the later, synchro box. The Archive does not hold a drawing of the crash box, sadly. He tells me he blames it on just having tested positive for Covid...
I had noticed, Hugh. The Light Car and Cyclecar illustration tells me all that I was curious about. The third and fourth gearchanges are tighter than the first and second. I knew I ought to know the answer why, and that illustration has refreshed my memory: I am moving two sets of gears along two shafts.
.jpg   DSC03014s.jpg (Size: 838.11 KB / Downloads: 327)
(09-04-2023, 10:17 AM)David Stepney Wrote: Some little while ago, someone (was it Tony Griffiths?) posted an illustration from one of the motoring magazines of a beautifully detailed cutout drawing of the 4 speed crash gearbox, but I am damned if I can find it. Can anyone point me in the right direction to find it please?
Yes, it was me. If you would like a high-resolution copy here it is: http://www.lathes.co.uk/austin7-2/img36.jpg
You can also sort through these 20 pages for more interesting illustrations: http://www.lathes.co.uk/austin7 with download instructions on the first page.
Technically it's only crash 1st and second 3rd and top are dog gears as on most motorcycle gear boxes. Terry
Thank you Tony. I have kept a copy to go with my Austin 7 file.
And Thank you Terry. I was aware. However, one can still make horrid noises with it if one gets it wrong.
