I am getting water in cylinder 1. I have removed head, cannot see any obvious damage to gasket.
I need to establish if water is entering via gasket, or via a porous cylinder block.
No obvious signs of damage/rot on surface of bore. I have refilled block up with water to very top surface of block in the (nieve) belief that I might see any water entering g bore after several hours and/or water level will drop below top face of block. Is there 'more scientific' way of determining if block is porous? Advice please.
I should have thought if the block is compromised you would be able to see something - a dark spot perhaps, or a crack - in the bore. I don't think leaving it standing is the best test, as under working conditions there's a lot more stress, pressure and vacuum at play.
I should have though a leaky head gasket (or warped head) is more likely.
Can you see any witness marks on the head? (e.g. often you see a sooty patch between no.2 & 3 cylinders where gases have been blowing by)
Have you tried the head for flatness on a surface plate or with a steel rule? (n.b. often they are slightly domed convex in the middle).
Sorry, more basic questions - what sort of head? and was it tightened down with a torque wrench, following the correct tightening sequence? Was the gasket dry or greased?
Car type: Austin 7s
Water can also enter the cylinders via a seeping manifold stud, a badly fitting manifold gasket and an inlet or exhaust port.
A good way to check for flatness on the head and block is to put a straight edge along each in turn and see if you can get a thin feeler gauge under it anywhere along it’s length and width.
John Mason
And more questions.
How much water was in the bore and did you do a compression test before removing head (and any time ago for comparison) and did the water appear after you had done any work or was it just that you had a misfire to alert you?
It's a HC head on 3 bearing bottom end.
Just been on a run, performed perfectly.....then towards end of run, started to produce clouds of steam out of exhaust.
Before removing head, did compression test....85, 85, 80, 85.
