Hole in the Floor
Hi,
What is this round hole for, please?  My car doesn't have one.
It is to adjust the brake pedal height, wing nut on brake rod. Only used on Ruby based models.
Thanks.  My floor's been replaced with sheet steel - from the side of a fridge or similar - so this feature is missing.
On my Ruby the cover for the hole is a circular piece of wood with a shoulder machined into it to prevent it falling through the hole. I don’t know if this is standard or if a previous owner has made it. The hole under the rear seat to lubricate the bearing between torque tube and prop shaft is a metal cover.
John Mason.
Somewhere else water can get in? And needs a 'round tuit' to fill the hole?
I've been on the look-out for one of them there round tuits for more years than I can remember
there is a wooden hole filler in my cabriolet it looks to have been there from new regards to all Rob.
Good lord, if the ford is deep enough for water to enter through the brake access hatch, serious challenges are about to present themselves.
(05-02-2023, 05:07 PM)Duncan Grimmond Wrote: I've been on the look-out for one of them there round tuits for more years than I can remember
I’ve got a lot of jobs — just don’t have time to get round tuit ……………
I have a square TUIT.......
For those that never get around TUIT
Peter
