10-04-2018, 02:23 AM
(This post was last modified: 10-04-2018, 02:26 AM by Austin in the Shed.
Edit Reason: add content
Is this the same as a J 75 Stuart?
If so I think they take quite a lot of power to drive them.
If its in a trials car the carb will need a good air filter.
10-04-2018, 09:12 AM
(This post was last modified: 10-04-2018, 09:16 AM by stuartu.)
I think it's Godfrey's cabin blower version of the J75, Dave. I've got one kicking around somewhere. I will be interested to hear how Wills gets on, I had a vague idea of using mine with the Grasshopper drive you machined for me....eventually!
Regards,
Stuart
Wills, do you have a boost gauge on your car? I would be interested to know at what rpm you see atmospheric on a steady throttle opening.
Regards,
Stuart
William - is this the engine from Barry Clarke’s Grotty Chummy?
HI Wills,
Just a suggestion before you strip the engine down check the cam timing with a Degree wheel & dial gauge also check valve lift,
As you need to know what camshaft has been fitted, when you have that information and post it on this Forum you will receive some very good advice on its suitability for your application .
PS When you said it was Smoking was that from the Exhaust or just from the breathers.
All the Best
Colin
NZ
