Good Evening all,
I picked up my new 1931 box saloon 4 days ago!
Being a 21 year old, and having learnt to drive in a modern day Corsa, but have owned 50s and 80s cars, the 7 is quite a difference espicially the clutch.
The clutch in my car seems to be incredibly bad. It has the 3 speed box out of a 32, and i have now got used to double declutching down. However I cannot cleanly select 1st or reverse without crunching.
I cannot believe this is correct?
Further the movement on the pedal is about 1/2 an inch, and doesn't fully disengage.
Is there any adjustment you can do with the box in the car? Or will this be an engine and box out and inspection?
Kind regards,
Mike
It is possible that the clutch levers are set too low, this can cause the clutch to drag and not release properly. however it is an engine out job to check and correct.
Thanks for the reply. I don't quite believe the clutch is slipping however this is my best effort at explaining the symptoms:
When I select 1st with the clutch flat against the floor panel, the car wants to move and the engine revs start to die... therefore when coming to a stop and pushing the clutch in, the engine dies without increase in revs. It won't select 1st without much grinding which can't be correct surely.
Ian Williams: when you say the levers are too low, is that the foot pedal itself is to close to the floor panel?
No, it is the toggle levers in the clutch I am referring to, the cornwall, bristol and dorset clubs all have good technical sections on their web sites which may give you some more insight into what I am suggesting. The clutch petal on a three speed box is held to the shaft by a cotter so can not be adjusted.
Mike, this is common problem with Austin Seven clutches caused by wear in the clutch release levers/clutch cover. A "bodge" to temporarily solve the problem; Remove the starter/cover assemble to expose clutch bolts. Slackening all the clutch bolts will allow the cover plate to move away from the fly wheel. Then remove one bolt at a time and inset a 1/4 inch flat washer between the clutch cover and flywheel. A tricky operation as you need to avoid dropping the washer into the clutch. With the 6 washers in place, tighten all the bolts, you should have better clutch movement. There is a chance that the clutch may now slip under load, as you have reduced clutch spring pressure. This is a temporary job, and if successful, simply delays the time before you remove the engine to do the job properly
Hi mike,
As Ian and others have said. Sounds like the toggle leavers will need adjusting and the only way is to remove motor & box from the car. You will most likely need to do one of the two modifications to the flywheel cover plate due to wear from the toggle leavers. Install grub screws to allow the. Levers to be st right or install a roller under the leaver and set the toggles by bending to correct heights. I did the later last year and it improved the opearation of The clutch a lot.
Bryan
Put in a double thrust bearing at the front end and then thew crankshaft will not float as much and cause problems. The double thrust will need a washer to get the dimensions correct. I had the clucth problems until i made this change.
