23-11-2022, 04:55 AM
After a long hiatus I've resumed my John Heath AD Van body kit build. The floor pan is now assembled save for a few rivets in the rear of the floor.
The sheet metal floor pan / under pan instructions are very informative and well described. There is a check list on the last page to identify the parts by assigned number or description. This being said I have four metal parts that I have no idea where they are intended to go.
Two are handed 1/8" thick L shaped "BODY FRAME PLATES" with what looks like 5/32" diameter countersunk holes in them on one side.
The other two are called part C24 "RISER WASHER PLATE" 3/4" by 4 inches with three 3/16"holes at 1 1/4"centers.
There is no indication of what these do or where they go.
Have any of you built a John Heath kit and can tell me where they go and what they do?
Any help in this regard would be most appreciated.
Regards,
Stephen
Regards,
Stephen
