Car type: 1937 ARR Ruby / 1928 RF (3)
Just done a service on my oil button - Been looking for guidance on material for a replacement diaphragm, but cannot see anything in previous threads. Have made replacement from an old rubber glove that seems to work OK on the bench with air pressure, but not sure if oil will degrade the rubber over time. Can some kind person steer me in the correct direction please. Graham D.
Hi Graham
I think A7 Components stock button diaphragms.
I am struggling to get mine to pieces. How do you remove the pressed in brass cap
Thanks for the info - Diaphragms now on order.
To remove the pressed in brass coller I just followed the Essex Club instructions, including using the Wife's best washing up glove, but I am not happy with this solution. Hence the request for the correct item.
Graham
