handbrake lever
Hi Vancevr
Look what has just come up on UK eBay.
https://www.ebay.co.uk/itm/385197183332?...media=COPY
It is just the adjuster but the second picture shows how it fits in the adjuster.
This is Tony Betts who will probably be able to help you with all the bits that you need!
I already talked to tony and he was unable to find the parts I was looking for
I can supply the threaded brass boss that is attached to the bracket with three rivets if that helps you.
Thanks to the many helpful people I think i will take a crack at making them myself. If that doesnt work out I know where to find you
