This is Tony Betts who will probably be able to help you with all the bits that you need!
Car type: 1929 austin 7 chummy AD
I already talked to tony and he was unable to find the parts I was looking for
I can supply the threaded brass boss that is attached to the bracket with three rivets if that helps you.
Thanks to the many helpful people I think i will take a crack at making them myself. If that doesnt work out I know where to find you
