Car type: ARQ Ruby July 1936
If you follow the application process for POR 15,, videos are available, you need a lot of preparation in terms of cleaning the steel then applying their chemical cleaner which then must be removed with clean water.
When coated with POR 15 minimum 2 coats, I used a tie coat grey primer and finished in the body paint Tekaloid undercoat and then top coats, for the chassis finished in good old smooth Hammerite black.
When I want to prevent rust into the future - especially on areas that aren't generally seen - I tend to use a wire brush, Jenolite or similar, followed by (red) Bondaprimer. Areas that can be seen can be painted black later. Most of us must have our preferred ways?
In the early days I used original formula smooth hammarite, it lasted for years and although a but prone to chips, I never had rust spread under it. I now blast, apply Dinetrol rust converter, a low build black etch primer and 2pack top coat. I am extremely happy with the quality and durability of this approach.
Thank you for all of these suggestions and recommendations, which all sound good. I shall have a good read and look at getting some paints.
The finish on my BSA motor bike frame has stood the test of time really well, but, frustratingly, I cannot remember what I used. I think that it was B&Q's own black gate paint or something similar, but I just cannot remember.
Jamie.
My chassis was extremely bad and I managed to get it blasted by a company who used a stainless steel blasting media. This got all the old rust off and left the surface with a microscopic layer of stainless steel impinged into the surface.
I then painted it with Smoothrite and over twenty years later it's still good.
The company who did the blasting no longer exist but it may be worth investigating.
Car type: 1933 trials special
I’d recommend Corroless chassis paint ,I get it from Arc Rite in Morecambe, they will post and also put it in an aerosol.It’s got rust killer, and is reinforced with glass fibre.Google them, cheers Peter
