![Huh Huh](https://www.austinsevenfriends.co.uk/forum/images/smilies/huh.png)
Anyway - that temporary external arrangement finally gave way last week and I thought it was time to replace with the correct spring(s) - I mean how difficult can that be??
I stripped the cover off carefully and the components do look similar to those shown on the diagram shown (widely found on a search)
The main section numbered 16 and the actuating lever are pressed together as a severe interference-fit with the broken spring trapped in between. My questions are -
1. Do I just use brute-force and ignorance to separate this item and having replaced the spring re-press the parts together- being careful with the matching flat section? Pressing together with a vice seems OK, but getting it apart??!!
2. If I complete that - it is fairly obvious where the one end of the spring (no.18) goes on the actuating lever but where does the other end purchase against to supply the compression of the spring?
I have stared at this for quite a while and it isn't obvious to me. A couple of pics of the actual item
Hope you can help me
