11-08-2022, 10:01 AM
Hi All
I have a 4 branch manifold on my special with which I am not completely happy. The plate is too thin at 5mm and the pipe bends make tightening the manifold nuts difficult. So I intend to fabricate a replacement. I have an 8mm plate ready (thank you Bellini) and now need to design the system.
Question 1…. The existing pipes are 1 1/8” OD. Is this ideal or would 1 1/4” be better?
Question 2…. Welding between the two central pipes looks difficult so is brazing an option?
Question 3…. What is the best “pattern” for connecting the pipes at the exhaust end. A single collector or a sequence of pipe into pipe?
Thanks in advance
Thanks in advance
