03-08-2022, 04:41 PM
3 of the valve pins won't let go of their stems. Before I break out the Dremel, any tips?
Stuck valve pins
03-08-2022, 09:59 PM
I found on my Ruby that any tight ones came out with a small punch made from piano wire. That was after they refused to come out with the aid of narrow nosed pliers twisting and pulling.
John Mason.
03-08-2022, 10:32 PM
My RP, so some unfathomable reason, has pin type valves rather than the earlier collett type and I had a similar problem extracting the pins. I suspect the problem is that, over the years, they get slightly bent and jam in the valves. I used a fine pin punch to remove then and replaced them with new ones (available from cherished suppliers).
04-08-2022, 03:15 PM
I had a lot of trouble extracting the pin but finally did it with a bit of persuasion from the hammer!
