Ruby Brake Cross-shaft
Hi John,
These drawings are really useful thanks, helps work out where all the bits fit.
I'll keep an eye out for the other brackets for another cross-shaft, was planning to fit it over the winter so I can still use the Austin in the nice weather, so I have a little more time to hunt out the other bits.
Cheers,
James
Hi
It's probably worth noting that brackets for the earlier cars with the self aligning bearings are very similar to the semi-girling ones, and the 8 chassis fixings are in the same place. The only difference is the diameter and detailed shape of the central hole, which won't matter if you are modifying them anyway to make a new bearing.
The diameter of the semi-girling inner shaft is 1 inch at the bearing ends.
