I realise that the answer to this question is - 'why didn't you look at Moreton?' but let's gloss over that!
Inspired by the rally to finish of my '34 Ruby's interior I've dug out the tatty remains of the rear blind and I now have a question. Does the horizontal steel rod go at the bottom of the blind with the dowling rod a couple of inches above it or vice versa?
Thanks
If it's the same as a late Ruby then the dowel goes at the bottom with a screw-eye in each end (to guide it down the strings) and a metal rod in the pleat part way up.
Thanks very much for that Peter. On mine it appears that the pull cord is attached to the centre the lower rod (that I now know is the wooden one) and then it passes through a reinforced hole in the fabric just above the metal one. Do you know if this is correct?
Hi Joe. Yes mine is a Mk1, I understand that the mk2 also is similar. I have now found a very good article on the Cornwall A7 Club’s site about Ruby window blinds (though it doesn’t answer the question of whether the cord passes though the fabric!). I was very pleased to buy the cream plastic hook and ‘pull’ from a Cherished Supplier at the Centenary doo and highly amused that these two tiny items cost £3.50 more than I paid for the car!?
Car type: ARQ Ruby July 1936
Hi Denis
If those are poor photos any I take must appear abysmal!
Thanks very much for that Denis. It looks very good, certainly it folds up better than mine ever did! Food for thought!
Thanks very much for that Peter, really helpful. I’m pretty sure that my original one had a steel rod in it for weight, but I suspect when I restored the car first time round I, incorrectly, put it at the bottom. I think I’m pretty happy now about how it should be made. The wonder of the Friends site! Thanks again.
