Just curious - those who have a scuttle tank with a screw-on filler cap - does your cap have a cork (or similar) gasket?
I never fill my tank more than around 3/4 full because I get fuel spilling out from the filler; filling up yesterday it just occurred to me that my cap doesn't have any sort of sealing gasket - is that my problem?
Cork or rubber, Steve? And how is it retained?
09-07-2022, 04:36 PM
(This post was last modified: 09-07-2022, 05:00 PM by Steve Jones.)
I didn't want to poke at it too much, Mike, for fear of the obvious happening this close to Moreton but I think most likely cork. If it were to be rubber, I'd have thought it would have rotted away years ago. It's a good fit into the recess to the outer edge of the cap. You can see the outer edge of the gasket is slightly deteriorated. It looks like it's been there for ever so I'd think it might well be original to the car.
Perhaps a suitably sized O ring in a modern material would do the job?
Further Edit: I've looked again, Mike and it does appear to be cork. However, my Lidl box of assorted sized O rings has some that fit perfectly. Can I post you one?
On the RN and Ulster I have leather washers. You can fill the tank right up to the gunnels and it doesn't leak.
I'm not sure about leather, a friend had a nasty experience when a wash leather was stuffed in fuel tank of his 1961 bus, it disintegrated causing mayhem in the fuel system.
Nothing unusual in that Tony, I regularly come to rest on mini roundabouts with the surprised driver of a modern able to count all the dead insects in my radiator.
Mine had a cork one, untill it fell out. I made one out of card which has been fine.
The bayinet type on the chummy however leaks like a sieve. So I cannot fill right up as noted.
Car type: Austin 7 Ruby 1938
Be careful about the choice of rubber O-ring. I tested one that I was considering using in a petrol application. I left it in a jar of petrol overnight. It swelled so much the ring thickness was more than doubled. Unfortunately I don't have specs for that O-ring, so can't tell you what material it was made from. I suggest testing any rubber in some petrol before using it.
