12-03-2018, 01:19 PM
When refitting the hinges to an RP door, the hinge sits part on the door skin and part on the timber reinforcing. Should there be a thin packing piece on top of the timber part so the hinge sits level with the door skin or is it mounted at an angle? Level or angled will alter the distance the door sits off the A pillar. Anyone help?
Reason I'm asking is that I have to do a quick re-furb on the timber as most of the screw holes are stripped. (drill & fill with glued dowel)
B
B
