Car type:
Just properly stripping a wheel down with the thought of putting new rim on and respoking. The return on the outer fold is perforated for 5" on one side only. While disassembling, I was struck by how solid the thing was despite 90 years of internal surface rust under the tube.
Talking with someone about where exactly the loading is, they remarked that cars essentially hang from the upper spokes.
So that suggests that the spoke 'holders' are crucial first.
My question - IS it possible to safely repair a rim - and in what circumstances? I'm assuming the remaining 1928 metal will be of better quality than that of new ones today.
I reently stripped a wheel of a tyre and tube, the rim has been bodged up with body filler in several places then painted. I decidd that the best way forward was to cut the centre out and send the rim to the scrap pile.
Iam unsure how long it had been like this, and it must have given service for someone
Hi Jon
Why would you repair a rim? It is such an important safety item that a new rim is well worth the expense. And while you are at it I would always use new spokes where possible.
I can't imagine how anyone would think it a good idea to weld up corrosion to a wheel rim or, indeed, use a rim with known corrosion.
I can think of lots of reasons why someone would repair a rim, after all, not all vintage cars are lucky that what are essentially motorbike rims are easily available and fit.
Note that I said repair.
Car type:
The question was IS it possible so worth asking for a component that is nonetheless eighty quid. It will move to the scrap pile!
Got spokes. I can see that JohnD's findings also compound the problem, as create a false security beyond merely stabilising surface rust at tyre change time.
Instead of welding and repairing components we could always replace with new, but somehow that isn't what many of us want. I would consider welding up a small rust hole in a rim but would want to use oxy-acetylene, as MIG is a bit too fast and not quite as controllable.
In the event I selected the best 5 wheels from my pile of eleven. These has some rust, some pitting, but no holes.
Recently I hit a nasty though small pothole. The bang was incredible but on inspection no damage - those wheels must be strong!
06-05-2022, 09:59 PM
(This post was last modified: 07-05-2022, 01:18 AM by Bob Culver.)
Very many wheels would have been repaired on Sevens and similar. Important no kinks or wanders including welding induced as cannot pull into shape as readily as with bicycles. Think one of the Club sites covers rebuilding.
Based on wheel lifting antics with my RP I have great faith in origianal spokes. Often too stretched. Many replacements of single gauge and look clumsy. Often nipples damaged. Dunno if can get the exact obsolete non Whit form cycle thread, or taps and dies for.
(Spectators were amazed at the distortions of the wheels of the Rubber Duck car when cornering, but wheels survived. Seems slip angle was not confined to the tyres!)
Spokes should not be treated with acid rust concoctions.
My heavy 1929 Dodge has 19" wire wheels which are unobtanium, 50 years ago I had a tyre explode because the rim had rusted under the tyre bead. The solution was to put the entire wheel into a lathe, part off the edge beyond the spokes and full circle weld on similar from a grey ferguson tractor. Still going, well to be honest I have'nt used it in 15 years.
