That reminds me of the fun father and I had in the 1970s running the 33 Box outside our house while the neighbour 3 doors down was watching the telly. I was fathers look out.
Every time the neighbour went to the telly to tune it I would signal father to cut the engine, TV Fixed !!! once the chap sat down again work on the Austin engine would proceed until the chap got up to re tune the telly.
This was good Saturday afternoon entertainment. !! especially on cup final day !!
I still have a few of the Acorn Suppressors in the garage.
Is this still relevant in the days of cable or satellite TV? My RP is fully unsuppressed.
Yes - still very relevant
Unsuppressed ignition radiates mostly over the VHF and UHF ranges, so terrestrial analogue and digital radio and TV broadcasts are affected, along with professional and amateur radio communications. You won't see white spots and hear clicks and buzzes with digital radio and TV, instead you get "freeze frames" and stuttering.
In the UK, suppression was a legal requirement for new cars from some time in the fifties, but the law wasn't retrospective.
However, I suspect if you go to your local radio and TV shop these days (If you can find one), you won't get a polite and knowledgeable lady who sounds like the Queen !
‘I believe you can still buy the inline suppressors for fitting to copper wire leads (not carbon I believe the carbon acts as the suppressor).
John Mason.
If you had a car radio fitted you also needed to suppress the dynamo with a capacitor and sometimes the wiper motor if the car was fitted with electric wipers. On rare occasions the car radio had to be wrapped in aluminium foil and earthed to get good reception without the continuous noises from other electrical stuff on the car.
John Mason.
Digital meters also do not handle ignition hash. For old car use a basic (1000 ohms per volt) analogue meter is more useful. Calibrate using much more accurate digital.
